haknslash
- Lake Martin, AL
- Moomba
- Other
Here's the video I made during my swap. It's pretty straight forward as you will see. Hopefully this helps others as they upgrade to intercooler to SVHO or aftermarket IC (same process applies more or less). I will be going with a Y fitting until eventually running a second dedicated outlet hose and additional pisser.
Two 14mm bolts and one 14mm nut hold the intercooler on the engine.
I'm also adding this image so you can understand how to visually identify the SHO intercooler compared to the SVHO in case you're shopping for one. Both are made by T.RAD Company.
SHO intercooler part number 6S5-13670-10
SVHO interrcooler part number 6ET-13670-00 (2015 and earlier) or 6ET-13670-01 (2016+). Either will work fine.
**Updated with videos
Here are bone stock top speed runs suffering from heat soak...
And here are some top speed runs after the SVHO intercooler upgrade. After multiple top speed runs and long periods of WOT driving the heat soak is gone....
