mbalogh
- Lake Hopatcong, NJ
Hey everyone,
I’m in the process of replacing the intermediate bearing on my starboard engine. Got the assembly out of the boat no problem after reading all the great advice from this forum. However, unfortunately, the coupler on the assembly is so rotted that we couldn’t press the shaft out of the bearing housing. It actually broke just tapping on it! So now I need to order a new coupler and install it on the shaft. So I have a few questions:
1) It looks like from reading parts diagrams and the shop manual that the coupler threads onto the shaft. Are these standard threads or reverse threads? Or is there some other way it needs to be installed? Judging by the rotation of the impeller it looks like they should be standard threads to me.
2) The shop manual shows a tool that you insert into the shaft which engages with the splines to hold the shaft still so you can spin the coupler on/off. Anyone know where I can get one? It’s a Yamaha part number YW-38742. There are no Yamaha dealers near me that I can take this to to have this done.
3) I see two o-rings on the parts diagram. But I don’t know where they get installed. Are the two grooves shown in my second picture where those o-rings should be installed? Because there were none when I took the assembly apart, and I’m wondering if this is why the coupler rotted.
As usual thanks for all the great advice!
