itsdgm
- Rancho Santa Margarita, California
Maybe we got the loud and less powerful unit. I did have to repair the H.P. hose right out of the box. Maybe mine could go all the way to 13-14 psi, but we do not like listening to it for that long. As you said it slows down once you get a few psi on the gauge and takes time to get to the 8-9 psi I stop at. From there 25-30 hand pumps gets me to 13 psi. Maybe there is still a leak in the hose, but I do not hear air escaping when I shut the pump off. For reference the board I am talking about is 11' x 32" x 6", so a little more volume than some but not huge. I think I am going to try the Airhead Super High Pressure 20 psi pump out.With that pump I can fill my 10'paddle board in something like the 8 minutes mentioned earlier.
I do not use a hand pump at all. I use the electric all the way to 14 or 15 psi. It inflates relatively quickly until it goes to high pressure mode, then it is much slower. Like 1 psi every 30 seconds or so... lol.
20 is quite a bit less than 28.The Super High Pressure Airhead requires a source of at least 20 amps, based on info in link above, and comes with an adapter to connect directly to battery as I am sure that the boats accessory outlet is rated at less.
Did this last weekend !Dont forget to set the valve properly before starting or you'll have to do those last ~80 pumps all over again!!
