haknslash
- Lake Martin, AL
- Moomba
- Other
Congrats! Glad to hear she arrived safe and sound!
Only thing I would add, is when folding it up in sections take all the material from the swim platform to the seat backs and fold it into the boat.As for the cover, best way is to remove from the aft. Unvelcro and loosen the strap. Fold it up in sections as you work your way forward from the aft deck. Installation is reverse of removal.
This is true...HORRIBLE design. First thing I would change is to a Rule Pump that is water sensing. Wire it directly to the batteries and never worry about that switch again. It has a test button for checking it and about monthly I would let the hose run into the bilge until it kicks on and pumps it out.(the real answer on the bilge: The pump is automatic. It turns on for a moment to detect if there is water. If there is, it keeps pumping. If there isn't, it shuts off. The switch on the helm turns on the power to whole system. So, if that is not on, the pump never checks and never pumps. If it is on, then it checks and only pumps if there is water there. Whenever the boat is in the water, that switch should be on!)
I just don't like the idea of rain water building up in the bilge over time if it's stored either. And I wonder what percentage of people remember that bilge switch every time out? If you don't have water, you don't drain the battery. If it's running and the battery drains, you at least kept up with the water while it had power. What about the guys that leave their boat in the water for extended periods, do they leave the switch on all the time, draining the battery because it runs every few minutes?Well, I don't know that I would go all the way to horrible. Remember, on the less expensive boats in the product line, the come with only 1 battery and no switch. So, then, the only way to turn off everything running on the boat would be to remove a battery cable. Personally, I like to be able to control what is on in my boat.
Now, that said, I could have been very happy had they put the switch for the bilge down by the batteries and left it on all the time (no light, thanks). They could have used that space on the helm for useful things you actually will want to turn on/off during the day. Like an auto-deploying bimini...
(Hey, Yamaha! That was a hint.)
Can you define "less expensive boats" please. . . . . I dropped nearly $50k on mine after taxes and I only got 1 battery. . . .Well, I don't know that I would go all the way to horrible. Remember, on the less expensive boats in the product line, the come with only 1 battery and no switch. So, then, the only way to turn off everything running on the boat would be to remove a battery cable. Personally, I like to be able to control what is on in my boat.
Well, see, that is the problem. That statement is false. The pump comes on occasionally to see if there is water there. If there is, it keeps pumping. If not, it turns off. But it is on a timer and constantly flipping on and off, testing for water. Were you to leave it on, it would drain your battery....If you don't have water, you don't drain the battery.
I think that the 242 LS is the only one that comes with the battery switches and 2 batteries. Mine came with one battery, too... So, in this case, 'less expensive' is the less than $60k ones...Can you define "less expensive boats" please. . . . .
While I agree this should in fact be the case, and is on my boat. . . . . I have seen others complain of rain getting into the bilge, and having the pump cycle nearly every trip to offload a few gallons. Knock on wood, I have never personally experience this.Rain water should never get into the bilge, at least in a 242 model,, You could turn on a hose, lay in on the floor of the boat and let it run all day and that water will never get to the bilge area or the pump. Same as rain water, it could rain all day and not get to the bilge. That water is all routed through a system of rain gutters (for a lack of a better terminology) under the fuel compartment cover and around the ski locker door.. All that that water is drained from the boat out the back end and straight into the river, never hitting the bilge area.
I think it goes into the engine compartment and pumped out with the pump. There are plugs in the front and back of the fuel tank compartment also and I think with all of them open they just become one big compartment. I guess I'll have to stick a hose in and find out for sure.You read my mind^... The ski locker has a plug, when i recently washed it out and opened the plug, where does that water go? Inside the hull to the rear drain plugs? Engine Compartment?
And to think I can still learn stuff from this forum! Thanks for the clarification @tdonoughueNo, that is the right stuff. There is a Yamalube-branded Yamaclean vinyl cleaner. Comes in a spray bottle...
