Adrian @ JB Solutions
- Tampa Bay, FL
- 252SE
What's the model # of the amp? Does it have a high-level/low-level switch?
Yeah the high low switch is a good point. Also any adjustable gain that you can increase? Any chance you can attach another source like from your phone or some other music player through a separate rca wire to bypas those rcas ?
Did you have any luck resolving your issues?I’ve got to be doing something wrong then, rfif2sw is a female version. Did I screw something up here?
well I’m still in the same spot I was before. New Rockford rca ends soldered on, and nothing but static through the speakers. My amplifier is only low input, so I’m guessing my problem lies there.
I can plug my phone with rca cable output to my amplifier and it works just fine....
what is the model number of the amp. If your phone works fine it’s not the amp.
I will look for the model number on the amp when i get home, but i think the problem lies in that the amp does not have high level input selection, only setup for low level. So, my assumption is that the RCA ends that im soldering onto my speaker inputs, is not really considered low level. Im honestly just not sure what else to try.
The new amp i ordered has high and low level, so it should work properly, i hope.
