adrianp89
- Tampa Bay, FL
- 252SE
That is 99% guaranteed your problem. Those connectors are called t-taps and are the worst invention in electrical history. I fix a ton of “professional” jobs because someone used them. They should never be used. I tapped the line level inputs, so we tapped the same wires. I found the wires right at the amp hard to reach so I tapped them closer to the connect screen. Use a military splice and this should fix the issue.
