campinfamily
- NJ
- FSH Sport
Hey everyone- we were lucky to get a 2021 210FSH sport delivered last October. There was damage to the middle tower piece from shipping, so dealer sent out to be powder coated....question 1. Is there a wire that goes in between the top, section and the bottom section were comes out of the helm? I called the dealer and they said no, it has to be pulled out of the top piece- I tugged and not much came out, and I’m afraid to really pull.
Question 2- for the battery wiring, where does the ground wire go? Wires are 2 red- 1 to each battery + , two black negative- 1 to each battery —, The jumper that goes to both sides of the negative, a small wire with a tag that says attach to negative, and then a ground wire. Does the ground also go to the negative?
sorry- newbie first time setting up batteries- dealer was zero help.
Thanks!!!
Thanks!!!
