Welcome to Jetboaters.net!
If you are talking about the directional arrrow on the transducer, the arrow points to the forward direction. This is a copy from the RV-200 thru hull installation instructions, we put in the Beneteau.
The one I installed was a 0° transducer. The one in the picture above is for a sailboat. They will typically install two, one on either side of the keel. The angles to compensate for the hull on either side of a sailboat keel. Mine is mounted forward of the keel, on a flat section in the hull, just one, and has one arrow on each side embossed in the x-ducer and it points forward to the bow. Picture taken at install.
where would mine have to correct ? its a 20 deg and the arrow is pointing to keel ( in other words ) directly to left of the location hole .. not sure if this is correct though
Garmin Support Center is where you will find answers to frequently asked questions and resources to help with all of your Garmin products.
support.garmin.com
But I would imagine that different transducers may have arrows pointing different ways, no? If it says keel, I would imagine that it should point to the keel (as opposed to the type that points the the bow). I think.
