Jim Robeson
- Springfield, Missouri
- Other
- Other
I know this is old... but @utahrd what is this gasket mod you speak of?That looks great Mel!
p.s. I did the cleanout tray gasket mod last weekend. i had totally had it with removing 4200 (again). every time i remove the cleanout tray i say "thank goodness i wont have to do that again...." and then 3 months later another mod comes along.
p.s. what do you guys do for stripped screw holes, as is common in the cleanout tray?
Picture?@utahrd and I have done a mod under the cleanout tray. We removed the screws that hold the tray in, and removed the old caulk and cleaned it off completely. Then we just used a gasket from Home Depot or equivalent. I used a vinyl gasket instead of open cell rubber, so it wouldn't absorb water. It was about 1/2"x1/2". I say about, because I measured compression and made sure I would get good coverage, it may have been bigger or smaller, and now thinking, it was 5/8" I think. It is backed with 3M adhesive with a peel off strip to expose it. Just place this under the cleanout tray on a clean face. You may find, depending on your boat year and model, that it is better to install this under the tray, vs on the lip of the boat that the tray sits in. If you put it on the boat lip, it is smooth, and sanding with 220 grit around the lip will give better adhesion. It is a great mod...makes removing that tray a breeze! I can get into the bilge anytime I need to.
If you had a daughter and she got married, would you say "had a daughter"?I had no issue with accuracy or disturbance. But again, I had a twin engine boat.
You can't sell family members.....that I know of....if you can...I have a SIL for sale! LOLIf you had a daughter and she got married, would you say "had a daughter"?
I dare say have a boat, just different household.
