- Buffalo, NY
Purchased our new AR190 this spring and picked it up in early May. We've been using it a ton this summer, and are already past 20hrs on it. It's been great so far, but I have a few questions I'm hoping some other more experienced owners can help with.
The "rear tray" leaks a TON on this boat.......Basically we've had it out a bunch of times and the bilge pump runs FAR more than I would expect from a brand new boat. It's not consistent though. Some days it runs a TON and some days it doesn't run hardly at all. I think I've tracked it down to how much we're in/out of the water on the rear of the boat, and how often water gets into the rear storage area. While hosing the boat down after a day in the river on the 4th I noticed that the water was continuing to drain once it was below the drain hole. It's leaking in past the panel that you reach through to get to the clean out plug. Not through the two access holes, the drain, or the clean out port itself, but around the edge of the tray itself. Is that normal?
There is a GIANT dead spot in the center of the steering wheel. While on plane I can move the wheel between 10 and 2 and get zero response from the boat. I've checked all the connections I can see at the rear and there is a little slop in each of them, but I can't imagine it adding up to this much of a dead spot on center. Is that normal? It sure doesn't feel normal. It seems to turn OK, and aside from a very big on center wander at no wake speed it really isn't a big deal, just doesn't "feel right". Any thoughts?
Whats the deal with the front of the boat having to be so dang high to get all the water out of it. We towed home LATE on Saturday night, and we just pulled into the driveway instead of our normal backing into the garage. I had left the plugs out since we left the ramp (~50miles away), and upon pulling it about another gallon or so of water came rushing out of the back of the boat. Our driveway is steeper than the ramps we frequent, but I can't imagine really having to be this highly angled to get all the water out of the boat (which also leads me back to question #1, where else is it coming in?). Any thoughts on this one?
And finally......Anyone confirmed/denied that the Clarion MF1 will work on the factory MA200 radio they put in the AR190's? Lots of threads about it working with other head units, but nothing about it working with this one. I saw where someone got it working on the MA505 unit that is in the 195, and it's not listed either. My suspicion is that it will work just fine once powered like that installation, but was hoping someone else might have already done the testing to confirm it. If not, I might end up being the guinea pig for it.
Thanks in advance for the help!
