swatski
- North Caldwell, NJ
Last weekend pulled the boat out and played with the two new impellers, pictured above. Couldn't do any real speed runs, because I didn't want to risk coming too close to any ice patches... I'm running with a new plastic ring, and have the Lucky 13 installed with NO spacers, didn't have time to play with that! Still have some cavitation to deal with... adding spacers will get rid of it, as my previous experience would suggest. But I will not gain much for top RPM or speed (with the same nozzle).
Basically, after all the repitching I gained back the RPMs, which is great:
1. Skat repitched to 13/15 by Glenn at Skat, max 8150-8200
2. OEM repitched 1* lower leading 1* lower trailing (also by Glenn), max 8050-8100
I'm hitting a speed wall of sorts, pretty much the same with either prop - in my short runs I was running up 43-44mph, hitting 45 couple times...
Not too worried about it as my boat is NOT set up for speed right now, dirty hull, rip in keelshield, etc - cost me few mph for sure.
Now, to put it in perspective:
My best speed with this set up is 48.3mph with Solas Concord 13/19; not bad for a N/A 190 but that prop cavitates badly on hole shot; can not cure it with L13 and I tried...
My best overall results so far (consistent speeds of 45-46mph and minimum cavitation) are with the unmodified OEM (6CW-01, factory pitch supposedly 13.5/15.9, OD 154.6mm); that prop is also the roughest riding of the bunch by a long shot... go figure...
The new Skat 13/15 will be tested and tweaked with the L13 cone with the spacers, I really want to make it work because I like the way it feels. We will see. I have the RPMs to play with, so it may work.
