mkbcaptain
- East NC, Surf City.
- FSH Sport
@brian86992 It’s happening!
The bilge pump is at the lowest point in the boat when sitting still. Where it is in every boat
I may try to retro fit the float switch to a lower positionThe problem is the built-in float switch is set too high
Went out today. Boat is still not hitting 7800-8000 rpm. Dealer is about to get involved.
It took me a while to find the answer on that as well, I ended up googling the correct method and the result I found was that you do not screw it all the way in when checking the oil on these motors, you pull it out, clean it, then insert it as far as it goes, but don't screw it in.I'm in the same boat as you all with the speed/RPM. My motors only hit 8k RPM when they're cavitating while turning/accelerating. Otherwise they top about 7500. That's 42ish with three adults.
Silly question but the maintenance manual is hard to decipher, to check oil level you're measuring from the dip stick screwed in, right?
Flexzilla HFZG503YW Lead in Hose,... Amazon.com: Flexzilla HFZG503YW Lead in Hose, 3' (feet), ZillaGreen: Home ImprovementBadass. I'm going to do the same. Did you find the short hoses at the hardware store or online?
