TommyMcK
- SW Florida / Middle Chesapeake
- Wake
Brand new 222XD. The thing was exhibiting "odd" behavior that wasn't consistent. I did a first quick shakedown running the boat a few miles last week from a ramp to temporary high and dry storage at a marina. I noticed some sort of error flash up, but wasn't quick enough to see what it was. The next time out (yesterday), the boat wouldn't start on the starting battery. OK, I wasn't sure what that was about (both start and house breakers were open during storage) but it started when I put the batteries in parallel. The boat then threw a few "BCU" errors. Again, not sure what that was about, but during the run, both start and main batteries were showing charge at around 14V, so I still wasn't sure what to make of it. This shakeout was a bit more involved, with a good 10 mile run down the Chesapeake from the Patapsco river, down to and up through the Magothy river and onto my lift. Seas were a bit choppy in places and all in all, it was a decent shakedown at relatively high speed. During that time, a few more error messages briefly popped onto the main display.
Bummer....
Made it onto the lift uneventfully (I have some observations about drive, but will save that for another post), went into the house for some lunch with plans to take it out in the afternoon to see if I could figure out what was going on. Turned the key to the on position, the display booted but shut back off. Hmmm... OK, turned the key on again and noticed that the house battery read about 9V, the start battery read about 10V and then it shut off again. Double bummer. Took the starting battery out and charged it fully. Put it back in, and bupkis. No display boot at all. Pulled the house battery, charged that fully, replaced it and still nothing. Threw the parallel switch, and turned the key on again, and the display threw a BCU error and turned off.
My lift isn't convenient to any ramps, and in general, I really didn't want to deal with a low speed tow for a couple of miles to get it on the trailer. I traced the battery cables into the engine compartment onto the bus bars and low and behold... Every single nut on every single terminal on each of the three bus bars (start, house and ground) were entirely loose and backed off, with one nut on the starter bus completely off and in the bottom of the engine compartment.
I'm shocked the thing ever ran at all. All's well that ends well though. Tightened everybody up and we're back in business. I'm assuming that the bus wiring from the bus bars to the battery compartment is a Yamaha thing and not a dealer installed thing, but somebody sure screwed that one up.
For reference in case any of you run into strange electrical problems, you might check bus bars. The red plastic covers in the picture below cover the start and house bus bars on the forward bulkhead behind the battery compartment, and the ground bus bar (bottom) is on the port side bulkhead next to ballast pump.
Bummer....
