Roger Vrooman
- Navarre, FL
- FSH
Hi center console team!!! Picked up a new 2022 FSH 255 about a week ago, and yesterday was the first chance to put her in the water...
1) Break-in Period--the owner's manual that came with my boat specified 5 minutes under 2K RPMs and then 90 minutes under 5k RPMs... Once in the 90 minute period, I used the cruise assist (either plus or minus) to vary my RPMs every couple of minutes or so... Seems like everything I read someone mentions the 10hr (first Mx) benchmark... Total, I have close to 4 hours on the engines, and "I would" consider that I have followed the Yamaha prescribed break-in and that is "completed"... When I hit 10 hrs I need to change the oil and filters (which I already have and it is ready for the oil change)... Is break-in complete, or am I misreading the manual, and/or are some folks just being careful not to run over 5K rpms until the first oil change???
2) The cooler compartment (bow. starboard), is not draining (please see attached pic)... Any ideas on how to make that water drain, or do I just need to vacuum it out of there???
3) Has anyone been inside the access panel on the T-Top and know how much room is in there??? I would like to replace the current stationary anchor light with a stowaway/removable light like the one pictured as an attachment... Is there room to mount this and have 3-4 inches inside the T-Top access panel and splice it into the current wiring??? *** HATE the location and Yamaha's design solution!!!
4). Looking for pics of where you guys mounted battery chargers, mounted portable toilets, and where do you stow all the life vests ;-)
5).My last E-series boat (2017) had an option to synch both throttles and usually only "1" throttle to control both engines,,, Couldn't find it in the manual or through searching the menus... Is that a capability of this boat??? *** LOVED this on last boat!!!
Sure I have a million other questions, but that is the main ones I have, after first trip out... Please keep the heckling to a min about my fenders, still trying to get that figured out ;-)
Thanks much
Rogman
Thanks much
Rogman
