Oh just pullin a 15 month old sbt engine
spatty99
Orlando, FL
Moomba
I had about 300 flawless hours on an MR1 SBT engine (and then sold the boat). It even had better annual oil analysis results than the factory engine.
Just curious, which engine option and warranty package did you buy?
Jaycav
Cleveland,OK
The one that failed was SBT standard. This time around I order the premium
Jaycav
Cleveland,OK
Took oil apart and cleaned/rebuild her. The screen did a good job of catching everything D346A7F7-8EB9-4CB3-808A-65B58C3ED306.jpeg
Jaycav
Cleveland,OK
Jaycav
Cleveland,OK
Jaycav
Cleveland,OK
My new motor is due for delivery Monday so I completely pulled old engine apart. I do believe the problem was the timing chain guide. The part of the guide that broke is where the tensioner actually pushes on the guide. I think it was just a faulty part. The pieces of the guide blocked the oil passage just enough to starve the last valve which ended up sticking. Piston hits valve, piston explodes etc. 79A5D94E-05B8-43B6-A22B-A80471449A5A.jpeg
spatty99
Orlando, FL
Moomba
I had the premium/Yamaha version, with the 2 year warranty.
Jaycav
Cleveland,OK
Jaycav
Cleveland,OK
That’s what I got this time. Let’s hope last longer than the last one
WREKS
Port Saint Lucie, Florida
@Jaycav Thanks for the continuous updates. I have some questions. I cannot see the smashed piston and broken lifter scenario without a broken timing chain. Is it possible that a plastic guide piece or whatever caused the guide to shred got between the cam and the lifter? Did the guide piece delaminate? What does the timing chain tensioner look like? Therefore, I do not see how you are responsible for this. Am I reasoning correctly?
Edit Second scenario: Delaminated chain guide allowed for loose chain leading to chain jump.
Jaycav
Cleveland,OK
The timing chain was not broke. The tensioner looked fine and was still Functionable. The guide did look like it delaminated. The chain seemed tight but your theory of chain jump which would cause a valve to hit a piston is a possibility and it makes sense to me.
WREKS
When I say delaminated I mean-the new guide looks like it has a thick curved wedge fused/plastic welded to it. That is the part that is missing from the failed guide. The chain tensioner pushes against that wedge. That should not have fallen apart. The slack created when that wedge came off the guide, could have allowed the chain to jump.
Jaycav
Cleveland,OK
I agree
Jaycav
Cleveland,OK
Jaycav
Cleveland,OK
anmut
Nicely done! Let us know your on-water results!
@Jaycav , do you did this kind of work for a living or hobby? I’d bet the former because you seem to have all the skills and tools needed.
I hope the new engine has no gremlins and lasts as long as you own the boat.
