Bowmax
- FSH Sport
Hello guys, first post here and new to the Jet Boat world. I just bought brand new 2021 210 FSH. Went to flush port motor, had flush kit installed on port side, ended up starting starboard motor. Rookie mistake I know. Only my 3rd time out on the boat and I'm still getting used to which ignition starts which engine so it sounded like the port motor was running and I had water coming out of on of the pee holes so I thought I was good to go. Well, 2 or 3 minutes later when I went to turn water off and rev motor to get water out and shut down, port motor didn't do anything and thats when I realized the starboard motor was the one running. To top this off, I only had the "Start" battery turned on so my connext screen wasn't on to tell me my motor was overheating. Once I realized everything that was going on, I turned on the "house" battery and connext screen turned on and of course said "turn off starboard engine, consult yamaha dealer". I let the motor cool down for about an hour, connected everything correctly, and flushed the starboard enging properly and everything seems normal, motor didnt sound bad or anything like that, but the CEL is still on and still giving me the "consult yamaha dealer" warning. Dealer is 2 hours away. Do you all think the motor is damaged? Is there a process to clear this CEL with engine starts and stops or something like that? Thanks in advance.
