Smitty244
- SX
I have a 2021 sx195 with 30 hours on it. I bought it new and the first summer I had it I was idling and sucked up a stick that was roughly 3” long and 3/4” wide. It was a small piece of driftwood. When I tried to throttle up I knew something was wrong because had terrible vibration. I idled it the rest of the way to the trailer. My dad and I pulled it apart to find it wedged in the impeller and ware ring area. Did not see any type of damage whatsoever. Ever since then the top speed of the boat is normal but from an idle if I just nail it wide open I get crazy cavitation. I don’t recall this before that happened. Does anyone have any thoughts? Maybe a small ding in a blade on the propeller?is it possible this would have damaged the ware ring? Long story short I’m wondering about a performance impeller. Is there one that gains you a couple mph without sacrificing bottom end? If so can someone recommend one? Also if I do this would it be worth changing the ware ring at the same time even with only 30 hours on the boat? Please help point me in the right direction and also any advice on special tools or what is involved in changing the impeller/ware ring is greatly appreciated. Thanks
