Plug repair kit - wtf am I missing??
anmut
Ordered the direct replacement from Amazon, it came OEM Yamaha. The Amazon product has two different pictures- top is exactly what my current plugs look like. Bottom is what I was sent as OEM - see the difference? They’re actually bigger in radius than my OEM too. I’m lost here.
What I ordered
What I received
Is yours the dog style lock or the twist.
That part numbet is for the older design
Twist. It’s a 2020, and the exact part number per Partzilla
Yours should be
From my many dealings with boats.net and partzilla ( same company) is the pictures can be unreliable
i rebuilt mine last fall..my notes say i used-
F3F-67609-09-00
one of your images of the box says - FOR-67609-09
order page looks correct, but they sent the FOR version?
F3F-67609-09-00
The main order page from amazon at the top says FOR not F3F
I've found that if you look by part number on Amazon, you really have to look closely sometimes, as they're horrible with giving me specific part numbers - they'll mix in anything close, and there's no rhyme or reason as to why the list of parts is so jumbled. It SHOULD show you the actual part number you're looking for first, and after all those items, any related items or similar part numbers should be shown.
Searching there, the first result was the old style plugs, while the second item was yours. They also had it ridiculously priced - $138.20, and no, that wasn't for both, that listing stated it was for a single plug rebuild kit! :oops:
Amazon really ticked me off with this one... I even paid for shipping to get it here in one day - should've looked closer at the listing.
Something that I learned to force better results from Amazon is to use "+" sign additions for a search. It's not foolproof, but it helps.
As dumb as it seems, searching
F3F+67609+09+00
results in ONLY showing the rebuild kit of that stock number for me - nothing else is listed, at all.
Problem is, I forget it all the time, and I only remember it when I have a frustrating search experience like you had
F3F+67609+09+00
That's a good hint. When I was doing this search, I was also in the middle of about 100 other things too - $35 mistake I'll learn from.
