AceKicker
- 252SD
Short version of this post. What are your best practices for keeping your PFDs mold-free if you keep the boat out of the water at a marina?
Full version:
I am looking for some daily (more like each-use) cleaning/upkeep tips. I have a 2026 Yamaha 252SD. We keep it stored at a marina that trailers the boat, rinses, runs water through the engines, then stores it on the trailer in a storage barn.
We were able to go out a decent amount during the winter, and it's less humid then than it will be in the summer. Water seeps in through the cup holders to the storage areas where we keep our PFDs. So, every time the boat is rinsed, which is when it's put up and taken out, water gets in where the life jackets are. Despite the low humidity (that's relatively low humidity), we have been getting some mold.
I could seal or have my dealer seal the cup holders, but they say there are times when those need to be accessed for maintenance, which would require undoing the seal. Not a huge deal, but a little more labor-intensive. I am not referring to the tubing that drains the cupholders; I am referring to the outer edge of the cupholders that are not completely water-tight.
To combat this, recently I have been going to the boat a few days after using it, opening up the compartments under the seats and pulling out the PFDs to air dry on deck. Then, a few days later, I go back and put them up. I have been keeping them outside of the storage bags to help reduce moisture getting trapped.
There has to be an easier way. So far I have thought about getting one more PFD storage bag, cleaning all the PFDs well, then taking them home and storing them in the closet between boating days. The con here is having to take them to and from the boat every time I use it.
Another option is getting a plastic bin and storing them in that in the head compartment of the boat. Hopefully, by them being dry in there they would not get any moisture in a plastic tub. Then I can leave them on the boat.
One benefit to the way I currently do it is that I usually need to go to the boat after using it to refill the gas from my two 5-gallon jugs. I don't have a vehicle that can tow it, so that's by far the cheapest way I can get gas. It's less than half the price of using the marina's gas. The marina is about 3 minutes out of the way on my drive from work to my house, so that's not too much of a burden, either.
Does anyone have any better ideas on how to do this? Also, has anyone else had the issue with the water leaking into the carpeted storage areas from their cupholders? I think someone posted on this forum before that the carpet is there to reduce noise. It doesn't seem to be the best material for an area that can get that wet.
Full version:
