Scarab catalytic issues
luisgnecco
HO Impulse
Scarab jet boat 2017 catalytic converter issues
According to the mechanic, I’m having problems with the catalytic converter because water is getting in, and the engine is shutting off after 10 minutes. Also, at full throttle it loses power and shows many codes on the computer. He tells me I can either remove it or repair it because new ones are no longer available. Any help with this would be appreciated.
Use the search engine on this site to search for solutions to your issue. I know I’ve seen threads on that issue here. Totally sucks scarab quite making the replacement parts.
