danny4255
- Scarab
- Impulse
I've owned it since new. 140 hours, over-maintain Rotax oil and filter every fall, new plugs. same time but not last season on plugs might have 40 hours on them, coil boots, and rocker cover after season 2. High-performance coolant after 2 seasons, complete flush/fill. STA-BIL 360 Marine Ethanol Treatment & Fuel Stabilizer and Boostane up to 91/92 octane ever fuel up. The only issue ever was cold misfire codes in the cold spring waters in Michigan. Resolved by running true octane booster
BOOSTane if anybody's interested. So running great all season except yesterday on the way back in for the day, at cruise 20/25-ish/ 5000 RPM's 2-3 ft waves were pretty rough. The port engine began the repeatedly surging between 5000 and 7500 (approximate) RPMs. Could obviously hear regular supercharge noise with surge. Both engines in Sync, no check engine light (didn't check for codes yet though). Shut off/restarted still present. Limped back. On trailer inspected, no weeds, prop, and wear rings look fine and same side to side. Called 2 local service departments today, never hear of concern, bring it in next week. Wondering if anybody with the same setup ever had a similar issue. Also, it always has had a cavitation-type sound on WOT hole shots, almost none with 1/2 to 3/4 throttle from a stop. Has trim tabs as well but this is with tabs up. Thanks if anyone can assist, Danny
