HangOutdoors
- Royal Oak, MI
Tonight I mounted the Second bilge pump, an Attwood Saraha 750. I mounted it below the waterbox under the hatch on a 3/4" piece of starboard across the keel channel with some 4200. I relocated my High water alarm to inside the back engine compartment right where the hole is to go back to the rear bilge. It is higher than the rear bilge but at about the same level as the Stock bilge. Anyhow... I am debating on which way I want to wire and looking for some input.
I have a nice LED Bilge switch but it is a 2 way. I could order a 3 way, Auto, Off and Man, or I could wire it directly to the fuse panel/battery for always on auto, which wouldn't be bad. Here are the diagrams. I am considering just wiring it without a switch. Not sure the switch really serves a purpose, unless I am missing something for the 2nd bilge pump.
I plan on wiring it tomorrow, weather permitting, after the mounting block sets.
