went out with my daughter for two hours last night,
what a pain to sit and fill those bags and not happy with wakemakers,
had one of my tsunami pumps burn up, called them about a replacement either $150. for a complete unit or $40. for the motor/housing, I chose the housing, they didn't tell me the old fat sac fitting wouldn't fit on the new housing (they changed housing fitting size), no problem I'll just swap the new motor to the old housing, easy enough but the shaft was shorter so it didn't get a good pump pressure I guess because it was only pumping half volume it appeared, now I get to switch the housings back and go find an adapter coupling, that on top of I still have a bad taste in my mouth from their original sale of my bags/pump when they told me I could put my big bag in the ski locker (pump hose was 2' short to do that)
so just an update,
Wakemakers generously contributes hundreds of dollars worth of give aways to members at  the Shelbyville event, that's why I don't really shop around and just call them and on my replacement pump and hose order even though I chose USPS delivery (it's the cheapest) I received my order in 2 days,
I'm cheap and it's cost me a lot of money over the years,  when my replacement Tsunami didn't work correctly I just decided it was a small price to pay to order another from wakemakers, called them again, advised ordered wrong part just want the correct one, their first comment was to buy the wrong one again because on their website said "recommended for filling", we discussed it more and finally settled on what I believed was the correct one to buy, gave him my card and 2nd replacement pump is on the way,
get home yesterday and decide to try to measure the pump housings to see actual differences, after breaking out the caliper and only notice mm difference (easily could have been my measuring technique) I put the new pump back in it's original housing and the distance to the impeller looked the same as installed on the old housing.
took it outside to a 5 gallon bucket hooked it up, water pushed about half way up the hose but not enough to force it out, took the pump out of the bucket while still spinning and noticed it looked like it was spitting water out the inlet,
I remembered my riding lawnmower starter bendix is centrifugal and if you hook the wires up wrong it spins the starter the wrong way and forces the bendix down instead of up and out,
I had to hook a new cigarette lighter up to the new pump (only came with bare end wire), I reversed the wire connections and it pumped the 5 gallon bucket dry in seconds,
When I originally hooked up the cig. lighter I tested on my work bench without water, I heard the whine of the impeller and called it good,
How it eventually filled the ski locker bag with the impeller spinning reverse I don't even know but the next time out will be smoother,
now I'll have a spare Tsunami
