Solar charging question
ezrider
252S
Hello all.
I have a 30w solar charger connected to my start battery. It is definitely keeping it charged while I am away from my boat since I have it at a slip.
Often times I hang out and relax on my boat at the slip and listen to music. I know the audio system uses the house battery.
My question is since I have the solar charger connected to the start battery, if I leave the emerg parallel switch on, will that allow both batteries to charge even though the solar panel is connected to the start battery?
If this is true, I would have to leave the house and emerge parallel switches on while I am away from my boat.
I could be totally off base here but since the emerge parallel works the way we all know it works, I thought it could perhaps work in the opposite direction.
Thank you for your input.
1WetBoat
Tampa
You already have the DVSR that takes care of topping off both batteries. You don't need to have the parallel switch on to charge both. It is a slower process than dedicated dual bank chargers but just connecting it to the start battery "should" allow it to charge the house due to the DVSR.
ezrider
252S
This is exactly what I needed. Thank you so much for your help!
FSH 210 Sport
Tranquility Base
As soon as the start battery gets to 13.2 volts the DVSR closes and parallels the start and house batteries. When the start battery voltage gets to 12.7 volts the DVSR opens isolating the two batteries. There is a little red light on the DVSR module on the batter switches that when on indicates the DVSR is closed.
