toddaltpeter
- Ilinois
was it difficult going to the courtesy switch?
Not really, Just spliced in a 3amp fuse and ran wire to each speaker But the 45KM604WL's are only a blue led and only require a 12V and GRD. If you go with something that is a multi-color or color changing LED, then I believe you will need a controller. You could probably still run it off the courtesy light switch, but you'd have to wire the controller in line. I just wanted blue, so it made my install easy
