HangOutdoors
- Royal Oak, MI
Yes I did.
@MilesPrower when you did this, where does the excess come out? I know the cables go into the steering assembly, so does the lube come out from an opening in the assembly, and can you point it out? Going to look at how the fittings at the jet look to see if this needs to move up the list of things to do, and I'm trying to figure out how messy this could potentially be at the helm area.
@HangOutdoors did you see this thread as well?
*Also, I used thin motor oil, but think I'm going to use @MilesPrower 's suggestion of gear oil. Motorex gear oil isn't the easiest to find (unless it's shipped), but I'm a big fan of Mobil1 and will try that with the weight of 75W90.
Yes I did.
I think in 2019 the steering was changed to use the closed assembly. The pictures in this thread show steering for 2019-current vs pre 2019. From what I gather the models from pre 2019 models you could lubricate from either end.
I removed the bushing through which the last bit of steering rod exits out of its housing, but I clamped my oiler hose over the second bushing through which the housing exits the hull... otherwise, oil just leaks out of that second bushing while you apply pressure.
Did you use anything to seal the bushing up, or has a friction fit been sufficient to keep it on?
