Kalg
- Other
Hi All, wanted to start this thread as I see some people storing the 21ft boats outside by paying so this information may help them. If you have 21+ ft boats, please provide your inputs and hacks as it may help others. Thank you very much.
- See the below link for description and pictures of SX210 (7'4" on the trailer) which was able to fit into the 7' Garage door opening. This member has a 20+ ft deep garage so he may had to store the SX210 diagonally and it may have taken more time to move around. But for people with 22+ ft dept garage, it may go straight into the garage quickly:
- If they can squeeze a Yamaha SX210 with a caster wheel into a 7ft garage door per the above link, then we may be able to fit an AR210 also after removing/loosening wake tower cables per the below link, which then pushes the tower height below the windshield. Someone said that from 2019 AR210 models, Yamaha gave extended cable by default so we may not have to attach the extension as shown in the link below. The link below is for removing the tower cable for an AR190 boat. I think it may be similar to AR210. Please provide your thoughts. Thank you.
