Switch left in water safely?
SeaDoo
Switch
I have rented a lake house for 9 days next summer. Will it be safe to leave the boat tied to the dock at the end of the day so long as I hit the bilge pump when getting out and again in the morning first thing?
Hmmm a pontoon boat with a bilge pump interesting. I had a regular and severly modified pontoon boat but the only bilge pump I had was in the live bait well I built so when I was sitting still I could arieate the water in it and when I was moving I had a feed line sending fresh water to it. Can not see what would be a problem especially in a lake . Tie up good and it should be fine.
If seadoo still uses the carbon seal I say not a chance in hell would I leave one in the water. Even a new one. If they have a carrier style bearing like they used to or like the yamahas it's not ideal, but should be fine.
I would think your bilge pump would be automatic…. Are you getting a lot of water out at the end of each day? If so anyway to keep that water out?
There is a switch that is wet slipped all summer at my closest lake for what it’s worth. I did see the owner there one day bailing some water out of the boat. Do these boat have self bailing decks?
I've seen on the Switch Facebook groups that people have and haven't had any issues, some have switched the bilge pump to an automatic pump.
