Swimmingly
- Falls Lake, North Carolina
- FSH Sport
You could drill to add one more hole and get these for each IC/bilge opening in the hull:
http://actionpowersports.net/product/ada-45-degree-billet-bilge-fitting/ (iirc from earlier in this thread).
I had the dealer's service guy drill a third hole in my brand new FSH Sport, for a dedicated 2d bilge exit, so I'll have three of these in a row (in silver)
O (bilge) O (bilge) O (coolant). Obviously you'd have a fourth, which would be even more appealing, at least to me.
I don't have a SC'd boat, but have built and owned SC'd and turbo'd cars. I'd expect to see reduced I/C temps with two dedicated exit holes in the hull, versus only one exit with a "Y" adaptor.
If you're concerned about the pressure and volume of water being high enough to get two exits to produce a flow, you can reduce the hose diameter for each of the I/C exits, since the backsides of these 45 degree fittings (in link) have hose barbs and could be adapted to attach smaller diameter hoses.
