Midnight2V
- Houston Area
Unless you could rig up a sealed system to the air hole on the aft wall so that it is pulling no air from the engine compartment, a cold air intake is fairly useless for reducing intake temps. If it were a pwc, it might make a difference, but we have a much larger engine bay. Part of the problem is the hot exhaust right below the air hole, the other is you are still at the mercy of ambient air temps. I leave the blower on while I have the engine on and it might possibly help circulate some air into the engine compartment at low engine speeds. I suppose you could extend the flex tubing on the blower over to the air intake, but the blower moves air the opposite direction.
At WOT engine speeds, the engine is moving somewhere just shy of 10,000 liters (9947 liters AT 6.4 PSI @ 7700 RPM) of air per minute. I seriously doubt that intake temp is more than a degree off of ambient at that point. Not a good scenario for a CAI application to provide any benefit. No one I know, or anyone posting on here that I have read, has reported any significant improvement from using one on an otherwise stock sho setup. Maybe it is different for the NA motors.
So no, I don't think a CAI would improve your hole shot on an otherwise stock setup by lowering intake temperature, maybe by reducing inlet restrictions if you aren't seeing max allowed boost, otherwise no benefit at all.
That said, Riva, R&D, Worx, 4-tec/greenhulk all have CAIs for roughly $300, but I question whether they flow any better than a oil/cotton filter in your stock air box that costs $120.
The good news for you Buckeye is you have a 192, meaning there is a much better, likely cheaper, way to improve your boat's performance. Let's start by acknowledging that IC heat soak is the single biggest limitation to your engine.
Before you do a CAI for $300, I would mod the IC. SVHO is $150-300 and a Type 14 mod runs about $300. You could do a pump strainer and dedicated line to the stock IC for half of that. Any one will give huge improvements. A ribbon delete by itself won't be much but it works great in conjunction with the IC mod and is convenient and free to do.
I cannot overstate the impact of the IC mod, it is literally a different boat as far as hole shot, top end, and turning speed. It is also extremely easy to do although it does take some time the first time. Any thing you do is reversible, and you are not taking the engine outside of Yamaha's designed performance window.
As far as performance, for those of us who are using an aftermarket IC with a dedicated cooling line, we are ELECTRONICALLY limited, not POWER limited. Every single one of us is hitting the electronic RPM limit. Until we modify the ECU, modify the jet pump, or prop up, the only things significantly affecting boat performance (top end) are - weight management, altitude, and water conditions...that's really it.
Yes, more power beyond what the IC mod gives could possibly give you better hole shot - if you could avoid pump cavitation or hitting the electronic boost limiter. As far as top end goes, you would have to either tune the ECU, or prop up before you ever need more power. Even then, these boats may be jet pump limited for thrust output. Time and brave souls will have to figure that out.
