Tailwaters
- St Joseph MI
- FSH Sport
So I went to re-install my t top on the boat after installing the new canvas. I noticed the dealer had installed lock washer under the lock nuts that holds the top sections to the legs. Only problem is the bolts are not even long enough to make it to the nylon insert in the nut. My gut tells me there should just be a flat washer under the nut? Was just wonder if someone could verify this?
