Welcome to Jetboaters.net!
My open box came. The amp looks very used. But the worst part: it's not even the right amp. They sent me an M1804. It's a little fella. Hopefully they can get me squared away with the right stuff.
Does the box look bad or the amp? The description said that open box units would be in like new condition. If the amp looks bad I would call customer service and demand a new one. I did. I had to send it back and order another because the customer service guy said the system would not let him ship.
We should try to compare side-by-side with the Clarion's micro, the XC1410, I would be curious. With two of those pushing 10 DBs, I do not have any desire for more sound/volume.
No, @Bruce, I don't have that. I'm not very sophisticated, as you know, I struggle to use a multimeter, lol. But I can look for it if it is something easy.
I bought a 25 ft 0 gauge and was bit long so remaining wire had to sit in the fuel compartment out of the way. 1 noodle i was able to get both wires in, then nope had to separate
Not sure how the 242 limited S with 6+ speakers are setup but I only saw 4 RCA output (front L/R, Rear L/R) from the headunit. if you were to add additional amp for 6+ speakers, you may have to split the RCA output
Never but Best buy open box "deals". I'm pretty sure they take a customer return for any reason and sell it add a open box with no testing or evaluation.
I bought 2 of these amps to give the 6 stock speakers some extra power. I'm left with 2 channels not assigned to anything, any ideas? I'm not a fan of the tower tweeters so will leave those as is or disconnect.
