HangOutdoors
- Royal Oak, MI
I have the Michelin Defenders on my 2020 F-350 4x4 CC SRW pick up, before that I had them on four other F-350’s. I do the top rotation, the only time I did not is when my truck came with five tires and wheels then I’d do a five tire rotation.
As @2kwik4u stated, you should have a careful look to make sure they are wearing relatively even, but otherwise that top rotation will take care of any uneven wear pattern. If the alignment is good, other than some rounding of the edges on the fronts your tires should be fairly even. Also depends on how frequently you rotate your tires, if you do it every oil change, roughly 8-9,000 miles your tires should be wearing fine. How are they wearing?
Old school, never turn around a radial, front to rear as soon as I detect wear on the fronts or the steer wheel starts to get heavy....
I have run everything on my 4wd trucks and Jeeps from Super Swampers, to Ground Hawgs, to BFG's MT, AT's, Cooper SST's, Goodyear duratrac's Hancook Dynapro AT/MT's, to General Grabber X3's, ATX's and have always done just front to back. Had a set of BFG MT K2's that I made the mistake of switching directions of those radial tires and regretted it for the rest of the length I owned those tires. They got 100% louder and rode like crap. Maybe its different on a All Season or all weather tires, but if you have any aggressive tread pattern, reversing direction of those tires is not advised.Agreed. Front to back, don't change direction.
100% is, exactly that!Feels like whats the best oil topic![]()
