Yes, highly. No disadvantage really other than slightly louder /throatier sounding boat, but more responsive and slightly more power and torque across the range.
I would contact RIVA about the intake kit (ribbon "replacement") - should come with full instructions. It should be similar to 1.8 and it is easy if you don't drop or loose any bolts and gaskets.
Use the screw trick to wiggle it out if it is hard to pull:
I would also delete the "snorkels" from air filter boxes (leave the OEM filters in):
Every bit of opening the intakes helps.
All totally reversible, too. But I do not know of ANY case where these mods would case any problems whatsoever.
It will essentially feel more like boating in cooler weather, with the engine breathing easier.
