FSH 210 Sport
- Tranquility Base
- FSH Sport
I am surprised the ribbon restricted the intake to the point that removing it increased your top speed by 2mph. I was thinking about removing the ribbons from my 2022 210FSH. Before I did, I put a vacuum gauge on the intake manifold downstream of the throttle body. The ribbon and air filter were still installed. At full throttle, the gauge showed 0psi of vacuum which means no restriction. I see 2 explanations. Either, I need a more sensitive vacuum gage or the ribbon and air filter do not restrict performance.
Has anyone else gained performance by removing the ribbon and/or air filter?
Thoughts?
And yes, you need an Inches of water gauge with resolution down to 1/100th of an inch. I gained 200 rpm on each engine by going to the RIVA K&N style filter, which was the same result as running no air filters on back to back to back test runs.
