Ericd
- Illinois/Florida
- FSH Sport
Can I also get a picture of the proper transducer location I have a Helex 9 with side imaging I am wanting to install with 1 transducer on my 210 fsh
I mounted mine EXACTLY like @HangOutdoors (thanks, man!) on my ’22 210 FSH, and in my first five hours of use it has been flawless.No. You do not have to remove the ride plate. no large holes in ride plate. Custom mount.
Look at my second post. That is how I did it. I use zip ties to secure wire to ride plate. Not sure what they are talking about. Others have used different custom mounting brackets.
Here is pic fully completed.
I also moved mine transducer a bit higher a few times so it is not as low as I was experimenting with side scan. Same mounting spot.
Search through the forums here there are several custom mounts people did on their own that work great as well.
I was thinking about making a plastic mold of the keel and leaving a roughly 3" (W) x 9" (L) flat spot on the base of the moldfor mounting, and then gluing my transducer to the bottom of the mold, which in turn is glued to the bottom of the keel. Should be zero sidescan interference. It's crazy, I know, so I don't know if I'll actually do it. But does anyone see anything wrong with it? Other than having to use a permanent glue, and also running the risk of it breaking off the bottom of the boat?
I probably wouldn't do that, could come lose and smash up your gel coat. Drilling holes in the ride plate or the gel coat is no big deal.
Also I have Zero interference with side scan
Transducer mount is designed to swing up if impacts something. The best performance is outsideWhat do you think about mounting the transducer in the bilge using silicone to get a good bond with the hull? I would put a tube under the transducer to allow the bilge to drain past.
The positives are the transducer is protected from impact, is mounted on the centerline, no holes through the hull.
@Coult45 what mount did you use? Custom or the one that came with the transducer?I mounted mine EXACTLY like @HangOutdoors (thanks, man!) on my ’22 210 FSH, and in my first five hours of use it has been flawless.
Made my own, based on @HangOutdoors version. Here are a few pics...@Coult45 what mount did you use? Custom or the one that came with the transducer?
