Tricked out FSH
FSH 210 Sport
Tranquility Base
Hey I’m not missing much!
Am I looking at it right - the articulating keel has been deleted? Makes transducer mounting straightforward.
That’s not where I’d put the transducer….id put a keel mounted thru hull if I was doing it as far away as possible from the pumps.
I cannot figure out why the articulating would be taken off….these boats already suffer from not enough keel at slow speed.
DriveX and HelmMaster equipped models do not have the AK. Read somewhere that the AK impacted the maneuverability when using the paddles/joystick.
Good eye! I should have caught the different buckets!
Mounting the transducer where the AK goes doesn't work well if you have helm master. Mine will blow the garmin transducer straight down if you use the joystick.
