FSH 210 Sport
- Tranquility Base
- FSH Sport
Woke up at 0200 couldn’t go back to sleep..While I was laying there engaging in a mental karate match on how I could use the new smart shunt I bought to monitor both the total and net output of the alternators of the TR-1 engines, could I do that with one shunt and then just change the wiring around to monitor just the house battery, or should I get another one and dedicate that one to the start battery.
I got up and stoked the wood stove and went online to review the smart shunt set up and discovered there is now a IP 65 rated version available. It has the same operational specs as the original smart shunt with the only noticeable physical difference being the wires for measuring battery voltage, battery temp, start battery voltage etc are already connected, whereas the original version has the user connect them in what configuration is desired. The original version is IP 21 rated which is rated for vertical dripping water and condensation. I found that the smart shunt can be used as a DC monitor or a battery monitor simply by changing the settings via the Bluetooth app. In the DC monitor configuration the shunt could be hooked up to monitor the total output coming from the alternators to the batteries, but the parasitic loads, fuel pump/ injectors/ ECU for running the engines is drawn before it gets to the batteries. I’m still not sure trying to figure out the total output going to both batteries is worth the trouble when all that really matters is how much charge current is going into the house battery, and the start battery aux monitor function does that. Once the start battery gets to 14.4 volts the charge current going to the start battery is negligible.
The topic of using the charging system to charge the trolling motor battery bank had come up again recently, and while I had researched this topic before by using a Trollbridge charge controller off of the house battery the engineers at Yamaha had said the left over available charge current was so little it was not worth the effort.
It also appears Victron has updated the IP 67 and IP 65 chargers. From what I can tell from a quick once over is that the IP 67 now has two charge modes, High and Low, with several charge levels / amps in both high and low charge levels. Previously the IP 67 had two charge rates-10A or 25A, now there are eight charge rates; 2A, 4A, 6A, 7A, 10A, 13A, 17A, 25A. The IP 67 charger is a grip at $210, but is by leaps and bounds better than any other on board-able charger I have come across. I have three of the IP 67 chargers on board for charging each one of my 100Ah LiFePO4 trolling motor batteries, my charge time went from 14 hours with the MinnKota 10A charger set to AGM to 3.5 hours with the Victron IP 67 set at 25A for LiFePO4 batteries. While not everyone needs that fast of a charge time, I do, many times I’d get home and plugged in at 2200 hrs (10:00PM) and wanted to head back out at 0600 hrs the next day and my batteries were still charging with the MinnKota charger, another advantage of LiFePO4 batteries is their increased maximum charge rate of .5C or 50A for a 100Ah battery so why not exploit that.
