Voltage regulator
Sigmund
Hello, recently I posted about my 2013 Yamaha AR 242, with new batteries and I am getting a battery voltage alarm that I can’t reset, I am only able to temporarily stop it from beeping. Someone mentioned possibly the voltage regulator may be bad. Partzilla says it’s #2 in the diagram. I pulled them both, is this the right piece? And how do I know if it’s bad? I can’t find a picture of this online, and all the other ones look different and can be tested. Part # 6DE-81960-00-00 number . Any advice?
Why did you replace the batteries?
I found your other thread on this issue
In that thread I as well as @VitaminSea gave you direction on how to test your system, did you complete those tests as there is no post in that other thread indicating that you did.
