drewkaree
- Central WI
She liked the idea and what you wrote, and I like Milwaukee tools, ordered the jacket.
Thank you for the recommendation!!
P.S. do you use any extra batteries, or any that are flat? sounds like the battery shape and placement is about the only complaint. We will see. I'm excited! More boating for me!
Here's hoping for success! I take along a just-in-case battery if I'm headed away from the house, but when I'm running the snowmower, I'm just outside the house and within range so I don't carry an extra in that instance. In your case, you may want two batteries, because you can use the battery pack to power other stuff, in case you need a phone charged or something.
I'm not sure how the ladies jacket is set up to carry the batteries. Below, I've attached a pic of my coat. The battery pack with a battery inserted is around 6" long, and inside that rearmost pocket is a mesh pocket to hold the battery. I try to keep it in there, and it will sit close to the 7 o'clock position. If you're used to carrying concealed, that's the best way I can describe the feeling. You tend to forget about it after about 20-30 minutes, and only reminds you if you bump it on something. Like I said, that's based on how mine fits/holds the battery pack. For my wife, she tends to somehow either work the battery out of the mesh pocket somehow, or she never puts it in there to begin with. What she's come up with is this - get it situated so it's comfortable, and then stuff a hat or something in that pocket to keep it in that position. Like I said, I'm used to carrying concealed, and it stays in the mesh pocket for me, so once it "settles in", I'm all good.
I dunno what kind of USB cables you have, but the battery pack is the small connector. If you ever need to use it to power stuff, I've never been comfortable with having it stuffed inside my jacket to use it, seems like it would strain the cord plugged into the battery pack or potentially snap it off, so if I've ever used it for that, the whole battery pack fits nicely in the vertical zippered pocket for that purpose.
The 12V batteries are rounded triangles, and as far as I know, they don't offer anything flat for their heated jackets. DeWalt has their own version of heated jackets, but I dunno if those take the 12v or the 20v. If it's the 20v, that'd be a deal breaker for me, those things seem like they'd be unhideable and uncomfortable. The 12V batteries they have are more flat-ish, but they still seem like they'd be larger than the Milwaukee batteries. Slightly thinner, but it's still a 2-3" square and about 1-1.5" thick.
If the ladies stuff is built anything like the guys' jacket I own, that thing all on its own with no battery will help to add to her warmth! My jacket has 3 settings, and it's uncomfortable for me to have it any higher than medium. Even my wife, when shoveling, will turn it down to low. Just sitting in the boat in the wind will be different, but like I said, even if it doesn't work out for the boat, I'll bet she still wants to keep it for walking around outside in fall/winter!
