Shannon
- Holly Springs,NC
- AR192
It's a shame. How hard can it be to design a system for a marine engine that doesn't leak? I would venture to guess it's done all the timeSad to hear. Somehow I thought the 2017 fish would be tweaked for the better.
I'd lay odds that you're probably going to find a super thin strip of silicone not doing much good. It's an easy fix though.I gotta check that out, got a feeling I need to seal that up too and obviously grab some marine grease
It is, and all it took was some silicone. The bilge was completely dry yesterday after a trip out on the river. Just do it right the first time Yamaha.It's a shame. How hard can it be to design a system for a marine engine that doesn't leak? I would venture to guess it's done all the time![]()
I had to reverse my one way drains. Factory installed them the wrong way so any water in the boat would not exit out. Makes you wonder what else theu did wrong!?Resultand yet another job a Yamaha boat owner has to complete for the factory!!!
That's just unacceptable. What kind of inattention or just plain laziness explains that? It would seem you have to TRY and install a one way drain the wing direction. What's going on over there?I had to reverse my one way drains. Factory installed them the wrong way so any water in the boat would not exit out. Makes you wonder what else theu did wrong!?
Thank you. I'll look say the link.Adding onto the long list of complaints. Why is Yamaha even using silicone on this boat at all? Might as well use chewing gum. At least it would be easier to remove when I am re-doing all the fittings that they should have done properly the first time. I highly recommend not using silicone anywhere on your boat (only real use is certain plastic to plastic applications).
Think of it like herpes - You might forgot its there most of the time but it will eventually flair up (leaks) and you will never really get rid of it (removal). Here is a great article on the different uses for each sealant / adhesive.
https://www.westmarine.com/WestAdvisor/How-to-Select-Sealants-and-Caulk
I personally try to use Butyl Tape or 4200 on most things. It is expensive, sure. But I reminded what my grandfather used to say "never enough time/money to do it right the first time, but always enough time/money to do it again".
Thanks @Scottintexas . Is this applicable to the SX and AR models also?@Amar Nanduri I've added this to the FAQ under "how to stop you FSH from leaking" tab,
EXCELLENT work, thank you for sharing, have had my boat out for only two weeks and this week my bilge was working overtime. I am going to test this area tomorrow and hopefully this will solve my leaking issue.Thn
Thank you! I finished the project today:
I siliconed the screw holes and the edges of the tray frame. Poured the water and noticed there was still a leak where the factory "silicone" of the tray met the frame -
Then I decided to silicone the underside of where the tray met the the frame...around the factory sealant. And as a last measure. I added rubber 5/16" marine grade rubber around the perimeter of the clean out tray. The results were better than I expected. Not a drop went through the frame compared to the waterfall I had prior to doing anything. Based on what I saw before, there had to be a few gallons making it in there over the two hours I was out.
View attachment 54097 View attachment 54098 View attachment 54100
PROJECT COMPLETE!!
You bet. I hope it all works out. I don't know if I mentioned that I actually had some water coming through the bilge drains. I re-siliconed those as well. The seal wasn't 100%. Safe boating!EXCELLENT work, thank you for sharing, have had my boat out for only two weeks and this week my bilge was working overtime. I am going to test this area tomorrow and hopefully this will solve my leaking issue.
How did you access those thru hulls?You bet. I hope it all works out. I don't know if I mentioned that I actually had some water coming through the bilge drains. I re-siliconed those as well. The seal wasn't 100%. Safe boating!
I just removed the black plastic plug covers on the transom with a screwdriver, siliconed the covers, and reattached them. The same for the changing room drain covers. If that's what you meant? I didn't need any special tools or access. Unfortunately, I found there was NO silicone on the changing room drain plugs. The transom drain plugs had very little and none around the screws which is where the water must have been trickling in.How did you access those thru hulls?
