Need A Vacation
- Mid-Mi
- Scarab
- 215 ID
So I’m looking for some input regarding using a weight distribution hitch with surge brakes due to our new boat purchase.
When taking the boat camping, we have a ‘06 Buick Rainier as a second tv that gets boat duty. 4.2, rear air suspension.
Due to buying the Rainier used, the receiver hitch sticker was long gone. I recently was able to find the receiver hitch weight ratings when using a weight carrying ball mount.
Max trailer: 4,000lbs
Max tw: 400lbs
Edited to add the max weight rating if the receiver hitch when using a wdh:
Max trailer: 5,600lbs
Max tw: 750lbs.
Loaded the new boat weighs:
Total boat: 4,800lbs
Boat tw: 470lbs
So it is either make a wdh (weight distribution hitch) work with the surge brakes, or try to convince my wife to buy another vehicle which may be a challenge. At least a truck, since we will need a second vehicle for our boys to drive soon, as they turn 16 in a few weeks.
I will need a pole tongue adapter, and am looking at the Reese trunnion wdh w/ 600lb bars. The Reese hitch head tilt is able to be adjusted pretty fine, due to the design.
So who has successfully set up a wdh, and do you have any tips?
The pole tongue adapter is suggested to be installed 30” from the coupler/ball center. That is exactly where the tongue pivot is. But Reese said it can possibly be 32” depending on the wd bars...
My thinking is if the chains are not under as much tension as they normally would be for a traditional tongue, that should allow the coupler to move forward when going down the road. That would also tighten the chains a little, transferring a little more weight back to the front axle.
Having the available chain length should also allow the coupler to move back, applying the brakes as needed.
So any input is greatly appreciated!!!
TY!!!
Max tw: 400lbs
Max tw: 750lbs.
Boat tw: 470lbs
TY!!!
