Wesley Cobb
- 242 Limited S E-Series
Went out this past Saturday...both batteries very low voltage. The blower would come on for about a second or so then go off and there was no gage movement. Took both batteries out and had them tested at Auto Zone -- still good just low voltage. Put them on my charger/tender for about 16 hours. Pulled them off Sunday morning then headed to the boat. Reinstalled...turned the key and the start sequence ran completely. Hit the buttons and nothing happened. Not even an attempt to spin the starter. Both batteries, once the boat is cranked and the CONNEXT display is on, show each is around 13 volts. Tried the emergency parallel switch and the engines started like normally. I am thinking one of the batteries is not holding the charge but why would they show as charged on the display? Any ideas? Right now, I am thinking I need to pull the batteries, have them tested again, then put them back on the tender for longer time.
