Winterize - Washdown & livewell
TomP
Greenwood Lake, NJ
I've got a 2021 FSH 195. I've never owned a boat with a wash down or a live well. I live in the New York area. So freezing is an issue. Does anything need to be done to the live well and/or the wash down for winterizing?
Thanks,
Tom
vesder21
Cleveland Ohio
I live in NE Ohio and I pull the drain plug in the live well and let it dry out with the hatch open. Other than that I change the oil and fog the engines and that's it!
You will hear different things from others, but personally I do not run anti-freeze or do anything else to winterize.
FSH 210 Sport
Tranquility Base
I didn’t have any issues with my FSH last winter.
one thing you will want to do is with the boat out of the water, I do this right when I pull the boat out of the water, start the engine and rap the motor to half throttle for about 10-15 seconds to blow most of the water out of the muffler. There should be a sticker on the stern of your boat describing this procedure.
As far as the raw water wash down goes, just pull the fixture off and remove the line at the back of the valve, it’s a slip lock type of fitting. Blow that line out to remove the standing water in that line. I didn’t do that last year and it was fine after the winter and it was out in sub zero temps.
Other than that, put the correct amount of storage fuel treatment in the tank, fill it, and take boat for a cruise.
My boat stays in a heated shop for most of the winter so I do not fog the engine.
