Has anyone found a wired remote for the Marine Audio MA200? I have looked online and can’t find anything, checked the forum as well and didn’t see a super clear answer. Thanks as always for your help!
Does yours look like the Jensen MS2013btr? I don't have one but looking at the pictures on google they look exactly alike just rebranded. If so you should be able to use a wired Jensen remote. I wired 2 of them on my previous AR190. One at the helm and one at the swim platform
Marine Audio does have a wired remote but you won't find it anywhere. I contacted them directly and asked if they do offer one because it does show on their website. You can only get it by buying direct from Marine Audio. It was about $100 if I remember correctly. I haven't purchased one yet but plan to do so before the next boating season.
Do you have it installed Kyle or Jeep Guy? This is definitely something I want to do since i feel like im always climbing back on the boat at the sandbar to change a song or turn up the volume. Does the wired remote plug right in to the back of the radio? How much of a pain is it to run the cable from the head unit to the swim deck?
@Colin MacEachern had that setup on my 2015 AR190. I had the Jensen radio that is identical to the marine audio head unit. Also Jensen and marine audio are the same company. Running the cable isn’t difficult. I’ve had to install the remote on the swim deck of my last 3 boats until I got my 240.
@redsand Have you installed one? I just ordered one and plan on installing it on the helm. This way I can keep my phone in the glovebox and plugged into the usb charging port while running Bluetooth.
I haven’t pulled the trigger on the remote yet. For almost $100 I might just get a new head unit that is Bluetooth compatible. Boat doesn’t come out of storage until April 6. Still weighing my options out.
I have been debating getting the remote in redsands post as well. I thought the "remote app" would be the hot ticket but it never seemed to work right and would usually require a lot of resets to connect, and then it would freeze up after a few hours of use. Could be an issue with the head unit I suppose.
I ordered the Jensen Marc100 which the wired remote that’s capable with the MA200 stereo deck in my 2017 AR195. Currently I run Bluetooth off my iPhone most of the time and use my phone to pick and choose songs and adjust the volume. However it runs my phone down fairly fast and with my phone in the sun it’s caused it to overheat a few times. I’m hoping this will solve my problem and I can just keep my phone in the glovebox plugged into the usb charging port. The only thing after I order it I looked at my dash and I’m not sure where it will fit for mounting.
@ThatJeepGuy I’m looking to run two Marc100 for my helm and swim deck as well, I was wondering how did you hook up a second remote? I only see one plug on my MA200 for a remote. If you did need any additional cables can you post a link thanks.
I think the parent company for the Marine stereos labeled as Marine audio, Jensen and PolK are made by ASA . My rear remote knob went bad on my 2017 242x and I ordered the MARC200 (Jensen remote ) that pugs into the the stock harness at the time amazon had them listed for $19 now they are $58 you can add remote control Y cable ad add up to 3 if needed it works . The hole needed for the marc200 is 40mm or 1 5/8'' it comes with the extension cable. These remote units seem to all work together and use the same plugs and pin out configuration and allow multiple remotes using the y cable shown below
below is info for the polk unit but it has other optional remotes that should work and shows the options available in wiring the MARC200 is confirmed to work with the polk unit
