Thermobrett
- Lithia, Florida
- Boatless
- SX195
I have a new 2022 SX 195, and recently when I go to use the boat, the steering is locked up. I do run in salt water down here in center Florida, but flush the engine and wash the steering system after every use. It doesn't seem to be from the helm that its locked, but more from the steering ram/arm on the pump. Could I be getting salt water past the seal and building up some scale/corrosion? I notice this when I bring the boat home prior to launching and can break it free but moving the helm back and forth. This last time I sprayed XPS corrosion resistant spray on the arms, but wont know if that helped until I use the boat next. Has anyone else had this problem? I'm fearful I may have a bad seal and water is getting past.
