195S wont accelerat over 20
cory9010
195S
Launched boat couldn't get over 4mph put in manhole rebuild kit now can't go over 20mph
cory9010
195S
Max's 5200 rpm then drops
Thermobrett
Lithia, Florida
SX195
Throttle movement seem ok? Any play? First time using the boat or have you used it before with no issues?
FSH 210 Sport
Tranquility Base
If your boat has a super charger then it sounds like the SC clutch needs fixing. Again if your boat has a SC, pull the hose off of the SC and see if the turbine spins both ways, if it does the clutch is bad and needs replacing
Thermobrett
Lithia, Florida
SX195
I believe the 195S is the towered supercharged version of my boat. Makes sense. At that RPM, the engine would be screaming with minimal movement.
jdkaeser
Cincinnati, OH
195S
Check a couple things:
-Spark plugs - Either replace or verify each is getting spark.
-Check the foam in the engine bay, some people have had issues with the foam being loose and getting sucked into the air filter box and cutting off the air.
-Verify the clean out plug is seating properly - install it and fill the top with water and crawl under it. If it is gushing, it isn't sealing. Should hold water.
-Make sure nothing is stuck in the grate or around the shaft.
-Verify the throttle spring is opening completely. With motor off, put throttle in full throttle position, pop engine hatch and go to the spring mounted on the left inside wall and see if it turns more or is bottomed out.
-Verify the reverse bucket is lifting fully when in forward and is not blocking the jet.
-Finally, check the supercharger clutch. Seems unlikely due to the age of the boat, but you never know. Should only spin in one direction, if it spins both ways it's trashed.
Hopefully it is something silly, I'd fill the clean out port first and see if it leaks since you worked on the plug last.
cory9010
195S
Plugs in the mail , just pull apart turbo and try to spin ??
fatboyroy
Sebastian, FL
What do you mean plug? If you have clean out plug problem and RPM goes up to 5K, it means its not seated correctly. Replace plug first before you start dismantling anything lol.
cory9010
195S
Clean out plug is good , spark plugs coming in mail
cory9010
195S
New plugs ,clean out good still same problem
FSH 210 Sport
Tranquility Base
Did you check the super charger clutch like I suggested? Your symptoms are exactly like those of others who’s SC clutch has gone bad.
WITH ENGINE OFF pull off the hose from the SC so you can see the turbine, if you can spin it both ways with your finger the SC clutch is bad.
FSH 210 Sport
Tranquility Base
That is more than like going to be your problem
cory9010
195S
Only spins clockwise
BrandonG
At full throttle you can't get it to rev over 5200 RPM? what does it do at full throttle, does it stutter or what happens?
I thoughts at first you may need to replace the impeller but if that were the case you would have cavitation and be bouncing off the rev limiter at full throttle
cory9010
195S
It's about 3/4 throttle gets to 5200-5400 after that just plateaus
lazergeek
South Florida
What altitude are you using the boat? If cluch is good then my guess is you have a bad coil pack or intake leak since you already replaced your spark plugs.
cory9010
195S
cory9010
195S
The engine is also like scolding to touch after 10-15 minute run time
Thermobrett
Lithia, Florida
SX195
Are the three pissers on the starboard side of the boat flowing when at idle?
