We have been looking to add to our boating options
zipper
Boston Whaler
Looks like you have been staying on course after reading this post from the beginning of this thread. šŸ‘
Good eye! Thanks for hanging on for 25 pages. The wife had her hand on the tiller for this one. I am looking forward to getting her up here where the bulk of the refit will be done.
zipper
Boston Whaler
Brought the catamaran cabin table home for refinishing over the Winter. It is 33 years old and showed its age and a couple of attempts along the way of refinishing, it was rough. It is a cherry plywood veneer surface with a solid wood trim around the perimeter. I am in the epoxy stage now, so it will look glossy. I will apply satin 2pt poly as a final coat.
I first replaced the old binding brass hinges with stainless steel.
Table surface before.
Keep sanding but be aware of the veneer thickness.
I had not sanded off enough of the old finish and it was obvious.
So I sanded that off and tried again...
2nd attempt at putting down epoxy, much better.
Mixing West Systems epoxy 105 resin and 207 hardener. I use pumps for metering.
2nd coat of 3 or 4 epoxy coats.
zipper
Boston Whaler
Thank you Scott for keeping my thread clean. Well done sir!
zipper
Boston Whaler
Itā€™s official now, just need to make the changes on the transom of the Name and hailing port.
zipper
Boston Whaler
We bought a few new pieces to replace older worn out equipment.
Firstā€¦
A new ATN spinnaker sock to help a short handed crew deploy and retrieve the orange spinnaker sail. Purple spinnaker sheets, control lines, in the foreground. 42ā€™ long, had to use the floor of her shop to get it in there without twisting it.
And a new Dickinson 2 burner stove top for the galley.
BigN8
Corinth, TX
Thermobrett
Lithia, Florida
SX195
zipper
Boston Whaler
FSH 210 Sport
Tranquility Base
Firstā€¦
That looks like a great stove top!
zipper
Boston Whaler
Thanks, wife has a good eye. Out with the old. We liked the 22ā€ 12v Majestic TV on the Bene. It will stay with the Bene. As our eyes get older, we choose bigger and she also got this TV /dvd player for the cat.
zipper
Boston Whaler
zipper
Boston Whaler
Update on the table...Finished the final coats of poly, sanded, steel wooled and waxed. Now that I have the process down I will finish the leafs. We like a satin finish
Got the Captains approval.
One thin spot of veneer in the back corner of the table. Not perfect, but I hear that is a direction, not a destination.
zipper
Boston Whaler
We have had our time with her. Learned a lot during our time together. Fair well with your new owner.
FSH 210 Sport
Tranquility Base
zipper
Boston Whaler
A new saga begins...bringing a 36' PDQ catamaran from RI to Lake Champlain, after the NY canal system opens in mid May. Many replacement part are ordered, some installed already, others done in the next month or so. Once here we have plans to build a new bimini frame and bimini/dodger with the frame bender on site. Neither of us like the "lines" of where the current one mounts to the deck.
zipper
Boston Whaler
The new helm seat Pedestal arrived today. Mounting, for now, the original Todd Cape Cod seat. The old pedestal was modified beyond my liking. Also, with no seat bolster an adjustable height seat will be beneficial at the helm.
Oldā€¦
Newā€¦
zipper
Boston Whaler
Making lists and provisioning for the trip. You can tell Willow has been making the lists.
This is the list from my trip last week.
And the lists from last Fall.
We are not listless when prepping her.
Coult45
Cross Lake, NY
"not listless" - we see what you did there...
also...I'm no expert, but I'm pretty sure that eggs are not in the nut family. And that is a shit-ton of spices (although pretty low impact on space/weight). I don't see extra batteries for flashlight, radio, or other critical emergency equipment. Also, duct tape? plumbing sealant tape?
impressive prep...as we would expect from you!
FSH 210 Sport
Tranquility Base
Looks like a comprehensive set of listsā€¦yā€™all are going to eat well!
zipper
Boston Whaler
Thanks, AAā€™ on board for the headlamps. 9v, C and D will check use in electronic flare, handhelds, etc.
Gorilla tape, Teflon tape, electrical tape in my tool ā€œkitā€. Lifeseal and 3m sealants are included.
