FLJetBoater
- 242 Limited S E-Series
Having a new issue on my 2020 242se.
engine starts fine when cold. Can start and stop 5-10 times without issue. Hooked up the hose and ran for 20-30 mins. Had the candoo hooked up. Temps got up to about 160 in the engine, exhaust was about 90 and no overheat. Turned it off, reset everything and went to restart and it stalled out. But now if I wait until tomorrow and go out in the morning it’ll fire right up.
Has fresh plugs and oil.
There is quite a bit of noise coming from the pump area but from what I can see and feel there’s nothing in there. I’m wondering if something’s rubbing or expanding when hot and not letting the impeller turn easily causing resistance and stalling?
If I pull the pump is it ok to run the engine with the pump off to check? I’d have to let it run for 30 mins again to get the engine hot to make sure it’s not the engine itself.
