sx998
- Jacksonville, Fl
- SX
Just wanted this to be searchable for anyone looking for help…
My 2015 SX192 started having a long crank before firing up. Then it started to stumble at idle at times. Never stalled. Finally it would crank but not fire up.
checked everything with the multimeter and fount that the Pickup Coil was out of specs per the manual. That part is attached to the stator. I had to buy a new stator/pickup coil. The engine has to be removed and the shaft coupling removed to be able to replace the stator and pickup coil. I did it in my garage. Part costs over $400 from Partzilla. That’s what was wrong with my boat. Not a kill switch. Not a hatch switch. Not the cam position sensor. Not an ECU. Currently in the Keys enjoying life with family and the Yamaha.
